What happened with "sections" (UI4 => UI5)
In UI4 it was possible to assign rooms to sections. This feature is missing in UI5, am I correct?
But what happens with this information when I update a vera2 from UI4 to UI5. Well I did do that and honestly I did not realize up to now that the feature is missing, I never really used it.
But now I happened to connect the iPhone App Automator.app to my vera2 running on UI5, and this app still shows sections when you try to browse your device by room. Funny enough all rooms I added in UI5 are logically not assigned to a section, and therefore I can not browse it’s devices by room in this app. I can only see rooms I already had on UI4.
I also have some Aeon Labs MiniMotes I use a scenecontrolers. If I add a scene to a room which is in no section, I can not assign a scene in the minimote’s settings, it is just not shown. As soon as I move the scene to an old room which was already on UI4 (and therfore has a section assigned) I see the scene and I can assign it to a button on the minimote.
So it seems that the section information is still available somewhere on the vera, and some apps and devices still seem to use it. How to I get rid of that? Or how can I assign new rooms to a section? Is this just an error / bug during the update procedure?
I was not sure where to open this thread, it fits in a lot of topics in this forum…
Sections were removed in UI5. Well the sections remained from UI4 to UI5. In UI5 you could not create new sections. This is something the Beta team has voiced to MCV to put them back. They did say they will add that feature back into UI5. But right now it is low on their list. I was one of them as I use sections to organize my devices and rooms. So if you went from UI4 to UI5 they are still there. There is no way of modifying the rooms from the sections.
  • Garrett
Correct. But as @garrettwp also mentioned, MCV have said they’ll put them back.
I was sad to see sections go, hence I have left in support for it in the upcoming ui5 compatible release of Automator.app
I am thinking of adding in a ui in my app to allow managing sections and room assignments
Thank you all very much for your answers. Its looks like I didn’t search long enough in the forum.
I am glad to hear that this has already been noted and will be solved sometime in the future.
I basically don’t care about the issue being low on mcv’s list, as long as it is fixed sometime in the future.
BUMP… maybe this has been moved into another area but I’d like to know if there is any added news on bringing this back.
In addition, given we have access to the units, are these “sections” held in a file on the vera unit or is there a way to set them manually.
No news. You would need to modify the user_data which is not for the faint of heart.
  • Garrett
Back in UI7 for sure?
I can’t speak to UI7 support, but as someone who used sections extensively I miss them. Couple that with the fact that I moved to a new house then upgraded to UI5 without realizing this feature had been removed. Hopefully there were brought back.
I think the answer is no; they are not back in UI7. ::slight_smile:
Thanks for the update. Not what I wanted to hear but it is not surprising either.
