Let me apologize in advance. I’m sure this question has been asked before, but I just can’t find it in the forum easily. I’m installing two new fans and would like to control it via my Veralite. What ceiling fan switch works with the Veralite/Z-Wave?
That’s only zwave switch that can control a fan with multiple speed levels is Leviton. There is also the Insteon / Altsteon route with the fanlinc. The Leviton fan controller is pricey and only controls the fan speed. I went the Insteon route.
- Garrett
I just need fan control, so that should work. Do you know any model #'s off hand?
My current fan switch also has a separate light button for the integrated light. Any idea how to handle this in a single junction box?
Thanks!
I have some Leviton VRF01 switches that I no longer use that I will be selling, since I no longer need them.
There is no drop-in Z-wave replacement for a fan/light combo switch.
You could:
- Expand the wall box to add space for a new switch
- Install a z-wave inline relay or dimmer for the light (either in the fan canopy or in the wall box)
This, after I just dropped WAY too much money on a set of these. I haven’t even received them yet.
This, after I just dropped WAY too much money on a set of these. I haven’t even received them yet.[/quote]Sorry! I have been absent for a while!
I noticed. Welcome back.
Hi @PurdueGuy
How many and how much are you selling them for?
As I mentioned in my previous reply, if you are looking for both light and fan control in a single gang setup, you’ll need to look at the insteon route (e.g. FanLinc).
- Garrett
Adding to what was said previously, as workaround (at best):
- Wire it to permanent power and only use another method of switching the light, if available (remote, pull cord, etc.).
- Not use the light / switch out the fan for one without a light. (We actually ended up doing this, as we had the light, but not wired to a separate wall switch / and were looking to lower the profile anyway.)
[quote=“oTi@, post:12, topic:176520”]Adding to what was said previously, as workaround (at best):
- Not use the light / switch out the fan for one without a light. (We actually ended up doing this, as we had the light, but not wired to a separate wall switch / and were looking to lower the profile anyway.)[/quote]
I LOVE this fan… took me a long time to find one that i really liked the look of. But i may just disable the light. We don’t use it that much, and ironically it actually came with a matching plate you could use in place of the light if you didn’t want it.
Thanks guys.
I intend to hire an electrician to replace the junction box, as that project is outside the bounds of my DIY skills. The way I see it, the price of the switches dwarfs the cost of getting a professional to install it.
