I’, still working on sending an email with the light level every fifteen minutes. Got everytign working and decided to only send that email during the day. For some reason, I can’t get is_night working. If I comment out the If statement checking is_night, the email goes right through. Any ideas? I thought is should be easy!
--starting out, strLightLevel could be nil and that causes a problem - can't add a nil value --so, lets set it so something non-nil if (strLightLevel == nil) then strLightLevel = " " end–go get light level
local curLightLevel = luup.variable_get(“urn:micasaverde-com:serviceId:LightSensor1”, “CurrentLevel”, 45)
–make curLightLevel non nil just in case
if (curLightLevel == nil) then
curLightLevel = " "
endstrLightLevel = strLightLevel…" , "…curLightLevel
–now send email
–we only want emails during the day, so check…
if not luup.is_night() thenluup.call_action(“urn:richardgreen:serviceId:VeraAlert1”, “SendAlert”, {Message = strLightLevel, Recipients = “xxxxxxxx”}, 18)
–todo reset curLightLevel by setting to nil or to " "
end – end check for night
return true
