Weird issue with UI5 and scenes with DSC alarm diarming from door PIN
Not sure if someone else can confirm this.
Create a scene that turns on one light, add the advanced part to disarm the DSC alarm
Trigger is a pin on a door lock
Everything works, but if you go back to that scene, edit it and add another light, then resave, for some reason the scene no longer runs. It seems to only work if you create it, save it, and never edit it.
Odd
I’ll confirm this when I get home. I actually edited a scene early this morning that disarmed my alarm as well as perform some other tasks.
  • Garrett
Thanks Garrett.
I actually find it strange, randomly another scene tied to my HSM100 doesn’t run sometimes. I attribute that one to the settings I have.
Curious, what are your HSM100 settings, Ontime, sensitivity, wakeup…
thanks
