I have recently installed DataYours on UI7. Shortly before that I installed the Home Energy Monitor gen2.
I have 6 of these showing up:
_GET_LANG(generic_sensor,sensor) 4
Under it it says “Level”.
I have one called _Temperature Sensor
One called Unnamed device that has “Watts KWH” under it.
All with ID Parent of 66.
How can I figure out what these are, or what device has an ID of 66?
I do see
<service_66 service=“urn:micasaverde-com:serviceId:EnergyMetering1” ControlURL=“/upnp/control/dev_66” EventURL=“/upnp/event/dev_66” serviceType=“urn:schemas-micasaverde-com:service:EnergyMetering:1”/>
[quote=“akbooer, post:2, topic:189012”]I don’t see how DataYours could be doing this. Looks more like a mid-configured HEM (perhaps it thinks it has 6 sensors?). But maybe not.
DeviceId 66 could be anything, it’s just a question of Vera using the next available Id.
What else have you changed recently. You haven’t been playing with Ergy, have you?[/quote]
1 - I never intended to make it seem that it ws DataYours, so if I dd, I apologize. As for the HEM, maybe, no way really to know.
2 - What do you mean by playing with Ergy? It’s installed.
My Aeotec HEM V1 does this about once week. I just restore each time it does it. It was doing it much more frequently (3 times a week)and I noticed the child device capabilities were being wiped. I set up a pleg condition that if it happens it configures the device until the child capabilities are restored. (Sometimes the configure fails so it keeps doing it every 5 minutes until it works)
Wouldn’t it be great if our friends at Vera could figure out why this happens and fix it permanently? If it requires work on both sides, wouldn’t it be wonderful if they’d work with Aeotec to correct the issue as well?
I have about 30-40 devices that start with “_” that are all related to HEM V1 - in the past I would delete them but now they cannot be deleted. It seems like they are multiplying weekly.
ID parent relates to Harmony Hub . I was trying to delete _GET_LANG(generic_sensor,sensor) device Engine automatically Reloads and device is not deleting. I was trying to delete via http command http://192.168.1.2:3480/data_request?id=device&action=delete&device=530 still not deleting.
@cw-kid I got it! Wasn’t Harmony Hub was Aeon SmartSwitch. I went to Commands and Configure node right now and _GET_LANG(generic_sensor,sensor) x13 disappeared!
