Hi there,
I’m currently developing a webinterface to interact with a Vera controller. The webinterface is ment to be a simpler version of UI4. The webinterface will be running on a website and that causes me some problems. The problem is that i can’t request data using this url:
https://fwd1.mios.com/xxx/xxx/xxx/data_request?id=lu_sdata
The browser shows the JSON data fine, but when I use that URL inside my code which runs at an another server, it won’t fetch the data. I think the problem is due to browser security restrictions. If I download the contents (php: file_get_contents()…) and decode the data it works fine. Is that really the only way to do this? There must be a better option. I’ve read something about JSONP which should be able to do the trick, but it seems that MIOS doens’t work that way.
Anyone having same problem or know a better solution?
