The icons changed to a blue circle from default on all PLEG, PLTS, Virtual Switch and Vera Alerts devices.
How can I get the correct icons back?
UI5, Web interface.
Thanks,
[quote=“SweetGenius, post:1, topic:185871”]The icons changed to a blue circle from default on all PLEG, PLTS, Virtual Switch and Vera Alerts devices.
UI5, Web interface.
Thanks,[/quote]
They don’t work remotly only when you login via local LAN.
If you are local try a different browser Firefox or chrome. Also the logos don’t do anything on a mobile device and the UI is only good your setup, so It’s not really a importance.
You were right. I was logged in remotely. I Never noticed that before.
Thanks for your reply and helping the new guys!
