On your wiki, you mention a web based luup plugin generator will be soon avaiable… That was at the end of november 2011…
So… What about 6 month later ? ![]()
There is the plugin editor on apps.mios.com. It’s not actually a plugin generator, it’s just a wizard for editing the main Luup files. You must update some files with the appropriate roles, Edit them, and enter Wizard mode. The wizard isn’t available for Json files.
Thanks.
There is a “plugin ui designer” or at least some documentation about the “D_plugin.json” file ?
I would like to write my own plugin but its a difficult task without documentation ![]()
You can find the documentation for the Json files here:
[url=http://wiki.micasaverde.com/index.php/Luup_plugins:_Static_JSON_file]http://wiki.micasaverde.com/index.php/Luup_plugins:_Static_JSON_file[/url]
Can anybdody give an update on the status of the web based luup plugin generator? Has the development been canceled or can we still expect it any time soon?
