WDHA-12 -- Almost had it
I was able to follow the instructions and get it to pair and act as a secondary controller. However, I wanted add some scenes, so I created them and assumed I have to re-copy into the WDHA-12. When the recopy didn’t work, I thought I should remove and re-add the WDHA – and that didn’t work. Next, I reset the WDHA and tried to re-add, and no luck.
Guess I should have let it be the first time around. Any ideas why it might not be cooperating any more?
Did you delete the device or Exclude it? If you just deleted it, you will need to also exclude it before you can include it again.
