Wayne Dalton WDHA-12 Gateway
Purchased a Wayne Dalton WDHA-12 to add to the network. The gateway allows Homelink controller in car to talk to Z-Wave network.
Can add to network as a Secondary controller, but am unable to assign Scenes to buttons on the device.
I know the gateway works, as I can manually add light dimmers to the Gateway and they turn on/off fine.
But, can’t have Vera talk to it, other than list it as a device in the dashboard (with a triangle).
.//A.
Did you try the new ‘scene assignments’ button under the ‘+’ for a device and then Z-Wave options/config?
It’s working, see here: http://forum.micasaverde.com/index.php?topic=1218.0
This thing works well. I followed the directions in the manual for setting up the controller as a secondary controller. If it still doesn’t work for you after following the instructions, try programming it when it is not plugged into AC.
