Wayne Dalton T-Stat Issue
I have a Wayne Dalton t-stat. I think it is common with some other t-stats as well.
Every once in a while the t-stat changes the temperature setting to a low temperature all by itself. I have programmed it such that if the temp setting goes below a certain point that it notify me of the change. I also have it such that if the requested temp is below 74 that it be set at 74.
I had thought I had some guests that were making the temp request. However, recently I had it make the request when the house was empty, meaning that the system did it by itself. Anyone else experience anything erratic lilke this or know if a solution?
How did you set the alerts and automatic temperature limits? When I change the temp manually at the T-stat, the new set temp is not reflected in MIOS.
I have the same problem. I have the app “ThermostatMinMax” installed. I have 78 as the min temp for cooling. When the glitch happens the setpoint is bound to 78 but causes my AC to run too long. I am in TX and it is over 100 every day
I do not recall this issue prior to upgrading to UI5 about a month ago
