I have a single HVAC system with two zones controlled by two thermostats and motorized dampers in each zones.
I set UserSuppliedWattage variable for each thermostat.
Wattage usage report works well when only one thermostat calls for heat/AC, but when both of them are triggered, I’m getting a double count.
Is there a settings or workaround to negate this wattage double counting?
