Water Meter
Hello, my name is Ruslan.
I had such an idea. Perhaps it is not new, but on the forum I have not seen. I want to make a water meter with Fibaro module. The counter is displayed on the site is working properly. It remains the case for convenience: it is necessary to count the cost of water per hour, per day, per month and per year. That is to create new windows, each of them carried a record and then all this is displayed in the My Alerts. The problem is this:
  1. How to create a virtual device count?
  2. How to read the data from the PC into this virtual device?
  3. The sum of the cost as an hour a day in expenses?
  4. How to produce records to My Alerts?
    I would be very grateful if you could help me!
@itlook,
Could you advice with module you (want) to use
Than it is easier to get an plugin for it
Rgds
Huib
This is FIB_FGBS-001 Fibaro module
What kind of signal you had in mind
If i understand well the input of the fibaro is binairy
So what kind of watermeter you want to use?
And what kind of signal this will provide
Pls advice
Rgds
Huib
I want to use a water meter with pulse output. That is to translate impulses into evidence at the site Veralite.
please use the calculator to see how different elements of your daily water use can be reduced to save water.
I do not think that Z-Wave coupled pulses to Vera will be very reliable or accurate.
Water meters typically pulse at 10 pulses per gallon. 12 Gallons/minute rate is quite realistic in a residential setting. That’s 2 pulses per second … And if there are any communications issues … you could easily loose pulses.
You should have a dedicated pulse counter for the meter … one that you can subsequently poll for current total usage.
There is a post somewhere here where somebody did something similar if not the same.
edit
It was for natural gas usage, but the principle is the same:
http://forum.micasaverde.com/index.php/topic,12145.0.html
