is there any luup code that i could use to reload the vera? or more specifically luup to stop a scene from running.
i have a scene that when activated by either a fire or burgular alarm, will flash the lights in the house. it’s a fantastic code but unfortunatly the only way to stop it is to let it time out or login to the vera webpage and manually reload it.
[quote=“fencing49, post:1, topic:184949”]is there any luup code that i could use to reload the vera? or more specifically luup to stop a scene from running.
can i have a luup code do this?[/quote]
What scene code are you using to blink the lights? There may be a simple LUA code that can be added to the blink loop that stops the loop.
I used the code in this thread (2nd post) to trigger all the lights in the house to flash on and off after door entry alarm. It has a loop count and delay you can set. It returns everything to it’s original state at the end.
