Excuse me if this has been posted and answered somewhere before, I have searched and could not find it. Perhaps I am not using the proper terminology to search.
I have a few VRI06, what I would like to do is when I press the switch to turn the lights off, I would like it to dim the lights to 50% and then turn them off 15 seconds later, or simply turn off the light after 15 seconds and forgo the dim part.
Is the best way to do this with a scene? Lua code? Special setting somewhere?
There is no way to configure this switches locally attached load to delay turn off.
You can use a scene that has a delayed turn off or a dim then off delay. But, pressing the switch’s paddle will always result in immediate action on the locally attached load.
Yes. According to the manual’s copious 2 pages, the “fade rate” can be configured, with the fade taking from 0(instant) to as long as 25 seconds. That’s much longer than I expected. Perhaps the extended fade will meet your delayed off desire.
