VRCZ4-MRZ with VERA
I’ve looked through the forum here to see if there was previous answer, but couldn’t find any.
Problem: I got VRCZ4-MRZ to work with Vera Light, but I can’t get the dimmer to work. I tried to manually set the Load switch to Dimmer in Device_type, as well as assign the correct category, to no luck.
Any idea on how to get the Dimmer to work with Vera ?
Several threads on this.
Other threads here and here.
Bug report here, filed in July.
@cdeenen,
Welcome!
The way I read your post is that you are expecting the built-in switch to work as a dimmer? That is not possible; it’s an on/off switch only. The dimmer buttons are to control any dimmers that may be associated with the 4 zone buttons.
