I’m new to this forum but I just purchased the Vera Lite, a Levitron VRCS1 Scene Controller, and I have two Z wave outlets that have floor lamps hooked up to them. All I want to be able to do is have the VRCS1 control both the outlets so that the lamps turn on and off. I have managed to get the lights to either turn on or off…but not both. I have tried using triggers, groups, and scenes, yet I can’t figure this thing out. Sometimes, when I press the button the lights will turn on, then off, then back on. Is there a tutorial on here that shows steps on how to use a scene controller with the Vera Lite?
I will snoop around the message boards to see if there’s an answer, but if anyone has any advice, it would be most helpful. Thanks!
Has anyone found a solution to this issue? I am in the same boat (new to z-wave, have a vera 3 lite, just installed a vrcs1-1lz and cannot get it to control anything appropriately. I see it in the vera dashboard and in the configuration screen I can set two scenes, 1 for button on, 1 for button off. Unfortunately this appears to do nothing.
I simply want to turn on and off a GE 45603 lamp module. I can set a trigger for a scene but then I’m stuck with getting just on functionality or just off functionality.
Can someone help me out with what I am doing wrong? Any assistance would be greatly appreciated.
Try [tt]A scene is activated[/tt] and scene number 0 as your trigger. Then, on the [tt]Advanced[/tt] tab, pick the 45603 from the drop down list, click [tt]Add[/tt], then choose [tt]ToggleState[/tt] as the action.
This may toggle the GE every time you press the VRCS1 (and the LED on the VRCS1 will not change).
