I’m wondering if anyone has done anything with VoxCommando, Vera, and Sonos together.
I’m thinking something like this:
[ul][li]User uses a microphone or Amulet remote to ask VoxCommando a question: “What will the weather be today?”[/li]
[li]VoxCommando recognizes this question and fetches a result and saves it to a .wav file using their TTS.Speak2Wave command[/li]
[li]VoxCommando triggers a scene in Vera using the Vera plugin and the Scene command[/li]
[li]The scene uses the Sonos Plugin PlayURI pointing at the .wav file saved from VoxCommando[/li][/ul]
I think this would be ideal because it wouldn’t rely on Google for TTS so Internet access wouldn’t be needed and there wouldn’t always be the risk of Google pulling the plug on their TTS web interface. Also, the Sonos could then be used for VoxCommando responses without needing to use the Aux in port (which doesn’t even exist on the Play1)
Is there anything in particular I’m missing to achieve something like this?
[quote=“lolodomo, post:2, topic:178880”]I don’t know neither VoxCommando nor the associated Ver aplugin.
But to play your WAV file with Sonos, you will have to make it available through a WEB server. But I don’t know if Sonos is able to handle a WAV file.[/quote]
It certainly ought to be able to play a .wav file as that’s exactly what the plugin does for the “Say” command. Web server is no problem.
Yes. The computer that would be running VoxCommando is in the basement but I’d like to make use of having these cool speakers everywhere in the house for this.
[quote=“ericonvera, post:4, topic:178880”][quote=“lolodomo, post:2, topic:178880”]I don’t know neither VoxCommando nor the associated Ver aplugin.
It certainly ought to be able to play a .wav file as that’s exactly what the plugin does for the “Say” command. Web server is no problem.[/quote]
Sorry but I know exactly what the plugin is doing regarding TTS and iit is not a WAV file but a MP3 file.
I’d be interested to see how this goes for you. I don’t have a Sonos but is there any way to set it up as an audio device in windows and then just set the audio output in voxcommando thus skipping vera?
Some of the Sonos devices have an Aux In port that you could use in this case. I liked the idea of utilizing Vera for announcements and the like. I have music playing through my Sonos most of the time and it’s very handy to be able to use their app to change music from several devices. That being said, if I want a whole house announcement made (“The front door has been open for 5 minutes. Turning off air conditioning”), I think it would be awesome to pause the music, say the announcement via Sonos, then resume. I was just hoping to use VoxCommando for TTS because it doesn’t require Google and I can make it interactive with a microphone.
Those of you who have it, are you able to share the xml config files etc needed, maybe there is scope to create a dedicated thread on the forum’s RemoteControl board, if someone is prepared to lead it?
@AgileHumour, I’ve seen you praise VoxCommando a couple of times now, so unless you’re on commission it would be great to see/hear more about what you’ve done with it (if you have the time).
