Vizia RF+ Scene controllers VRCS4-1LX and Zone controllers VRCZ4-1LX
I’ve had no luck programming these with Vera. Only the on side of the zone controllers would work, the scene controllers would not turn on and off, ect. The new update 1.1.319 was supposed to improve this but did not work in my situation. I found a fix that works for me. I transitioned from Think Essentials and still had it laying around. I added Thinkessentials as a secondary controller. I removed all of the scene events for the controllers from Vera and added scenes to TE and programmed the scene/zone controllers from TE. It worked great. TE programs the controllers well. Everything works correctly. I put TE away. The only thing I worry about is whether Vera will try to reprogram the controllers, removing the scenes.
