Jonathan,
Welcome to our forum. Feel free to ask anything you want. No questions are stupid, except for unasked ones. I’ve found the MiCasaVerde forums to be very informative useful to work through a learning curve.
Since Vitrum is marketing only to Europe and the UK currently, all these switches are new to me and I have not worked with them yet. I must say the all glass switches look absolutely gorgeous. I’m assuming you are in the UK. Vitrum’s BS standard is designed for the UK and is for their square format wall switches, while the EU standard is for their horizontal rectangular format wall switches. The difference between the two appears to be mostly physical layouts.
Here is the list of ZWave hardware that is known to be compatible with Vera: [url=http://wiki.micasaverde.com/index.php/Supported_Hardware]http://wiki.micasaverde.com/index.php/Supported_Hardware[/url]
After looking at Vitrum’s specs, it looks like everything stands a very good chance of working with Vera. I have worked with Vera for about six months now with a variety of ZWave products. I feel I can give you a good guess where I would expect some challenges:
It looks like you should not have any problem operating the single switches and dimmers with a European version Vera3. You might have a small hitch with the double, triple, quad and hex switches. I would expect that the inclusion process would normally create 2, 3, 4, and 6 switch controls in the Vera dashboard, but I have not seen that feature demonstrated in the US version, since our switches are all single-gang behind the faceplate.
I would guess that their shutter control would be fairly straight forward. It will probably work right out of the box.
Based on my experience with other remote controls on Vera, the remote control will probably work as a secondary controller. It will probably work all four scenes very well. My prediction is that it won’t work well with individual lights. I’m generally not so happy with Vera and it’s compatibility with remotes.
There are apps compatible with Vera for a variety of cellphones. I have an Android and find HomeBuddy to work quite well for what I need. I think you will be able to find something for most any cellphone.
If you don’t hear back from anyone else, I would still definitely give Vera a try with a several representative samples and see what works and what does not. Vera seems to do a whole lot more than their “Router Home Master” today. I think most issues with Vera and the Vitrum switches can be ironed-out fairly quickly. But I’m not one to speak for MiCasaVerde.
I would love to hear how your project goes,
kgrr
