Hi
Has anyone gotten this to work? I’ve just got mine, and unfortunately can not find any information how to configure it ! This is a 4 button scene controller, so it is only wired into mains and doesn’t control anything directly. It is appearing in Vera as a master client (although, I did expect 4 clients to be honest), but you can do nothing with them. When you press a button it sends a command that it has activated scene “99”…and if I put a trigger on a scene that watches for this it will work, but, all buttons trigger this “scene 99”.
I’m sure I just have to add some parameters in the vera configuration… but… no idea what as there is absolutely zero info about it. (I would assume it’s the same as a key fob I’ve just configured, where I found the parameters to set from another webpage; after that, the buttons activated a different scene number for each button).
Would love to know if anyone knows how to configure this?
Some log info:
06 03/22/13 0:50:25.416 Device_Variable::m_szValue_set device: 231 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 0 now: 99 #hooks: 1 upnp: 0 v:0xa99af8/NONE duplicate:0 <0x2bd9d680>
06 03/22/13 0:50:25.417 Device_Variable::m_szValue_set device: 231 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1353545339 now: 1353545425 #hooks: 1 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bd9d680>
06 03/22/13 0:50:25.419 Device_Variable::m_szValue_set device: 230 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 0 now: 99 #hooks: 1 upnp: 0 v:0xa99af8/NONE duplicate:0 <0x2bd9d680>
06 03/22/13 0:50:25.420 Device_Variable::m_szValue_set device: 230 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1353545339 now: 1353545425 #hooks: 1 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bd9d680>
06 03/22/13 0:50:34.596 Device_Variable::m_szValue_set device: 231 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 99 now: 99 #hooks: 1 upnp: 0 v:0xa99af8/NONE duplicate:0 <0x2bd9d680>
06 03/22/13 0:50:34.597 Device_Variable::m_szValue_set device: 231 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1353545425 now: 1353545434 #hooks: 1 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bd9d680>
06 03/22/13 0:50:34.599 Device_Variable::m_szValue_set device: 230 service: urn:micasaverde-com:serviceId:SceneController1 variable: sl_SceneActivated was: 99 now: 99 #hooks: 1 upnp: 0 v:0xa99af8/NONE duplicate:0 <0x2bd9d680>
06 03/22/13 0:50:34.600 Device_Variable::m_szValue_set device: 230 service: urn:micasaverde-com:serviceId:SceneController1 variable: LastSceneTime was: 1353545425 now: 1353545434 #hooks: 1 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bd9d680>
http://www.vitrum.com/eng/content/vitrum-scene-control-panel-1
