Vistacam SD Motion Sensor only activates when 1 foot away
I am using a Vistacam SD and installed the Motion Sensor plug in. The configuration worked well for awhile then it stopped working and I had to re-install. I re-installed both the camera and the motion sensor plug in. Right now it only triggers when you are about 1 foot away from the camera. I have tried to readjust the camera settings, but nothing seems to help. Any suggestions?
Also the State keeps changing to 2 and the device file will change to D_DigitalSecurityCamera2.xml and then the camera doesn’t show up on my ivera iphone app.
Thanks,
Michael
