VistaCam - blinking white LED
this forum has been great in helping sort things out… I installed my VistaCam PT and got it working well with your help by downloading the I_VistacamPT plugin. my question is that I have a white LED doing a fast blink on the front of the camera. Is this normal? can I shut it off? what does it indicate?
Thanks for your help
You can disable it by logging into the camera’s IP address directly. There is a setting (I can’t remember what it’s called) just set it to disable. My camera is now setup remotely so I can’t access it’s IP address as I haven’t configured port forwarding for it. I hope this helps.
