Vision ZP 3102EU stops working after several days
I bought a bunch of these from Vesternet ages ago but only just got around to doing the security aspect of my HA
I’ve been able to include the PIR (no problems) and have set parameter 1 to 1 (60 seconds)
Everything appears to work fine for a day or so, but after a while it stops sensing movement. The only way to get it to work again it to remove the battery and re-insert it, then it will work for a while before it becomes non-responsive (the battery is new and the device shows a full green battery). I’ve tried three of them and all do the same. Could I have a bad batch? FYI there are a three jumpers (PET1, PET2 and TEST) non are linked.
cheers,
Philip
still having problems with the PIR sensors, IMO they’re a POS!
Can anyone recommend a reliable (small) zwave PIR please?
