Vision VS-ZD2102 Door/Window Sensor UI5
Hi all,
First time user… I know its going to be painful
I have updated my vera 2 unit to UI5 and have tried to include the door sensor Vision vs-zd2102 2015 zwave plus , the device only reads as generic io :frowning:
Since I am a noob and know nothing… chances are I either bought an incompatible device or something is really wrong!
Only info it gives:
device_type: urn:schemas-micasaverde-com:device:GenericIO:1
altid: 3
device_file D_GenericIO1.xml
There is not much more provided.
Anyone got any idea’s or is it a lost cause?
thanks all
Arnie
I have changed in Advanced:
Device Type: urn:schemas-micasaverde-com:device:DoorSensor:1
device_file: D_DoorSensor1.xml
When I try to run a ping test it keeps saying none of the pings were successful…
