Vision motion sensor EZP3102-5
Hi
Anyone got the new vision with zwave plus hooked on there vera lite with ui7? Cannot get it to work. Its says need special parameters. Its sees the temperature and the motion sensor but with red error line.
I can’t find an EZP3102-5 but I did find a ZP3102. Which looks very similar to my MonoPrice PIRs.
The only special parameter I know of is the one for the untrip timeout the value sets the minutes. I use 1 for a 1 minute timeout.
Variable name : 1
Size : 1 byte hex
Value : 1
If this is a newer model, you may have to contact Vera support so they can hopefully tweak the next release if it needs special setup.
Hi
I had the same problem with the vision EZP3102-5
I could’nt get it to work.
There isn’t much information on it eather
I tried everything. including with the cover on, with the cover off. Partly on an partly off. pressing the tamper switch during some stages of the inclusion proces. Nothing worked
I always got one these messages in a red error line:
Setting Special settings
Unable to get info on node
Cant detect device
The sensor was always wright next to the sensor.
Tonight I finaly got it working, but i dont realy know what i did different this time.
What i do know is that i made an association in the sensor with my kitchen light.
After that i pressed the program switch a few times and later on i opened the cover and pressed the program switch once moe.
Probably not very helpfull but perheps its a start for someone with more knolledge of Zwave then me
