I have added a vision door sensor in vera lite but it is not working properly I have tried to remove then add the device again many times but it the sensor is not working properly it will only trip after 1 min. when the contact is open there a way I can reset the sensor
each time I remove and then add the sensor it behaves the same way need help !
I want to factory reset the sensor I think I am missing something
