Other than creating very basic scenes is there a plugin that will allow me to more fully control my thermostat based on temp sensors I have around the house? I have two heating systems in the house, and one has the thermostat installed in a terrible location which isn’t really fixable, top of stairs outside the master bedroom. If I close my bedroom door that thermostat will not get enough heat to shut off. I have an Aeon 3 in 1 sensor in the bedroom, I’d like that thermostat to mostly ignore its own temp reading and act based on the reading of the external zwave (Aeon) sensors I’ve installed.
Failing that I’ll try and use PLEG to accomplish the same thing. A plugin that mimics a thermostat and does this for me is cleaner as I can change temp settings without having to edit the pleg.
Paul
Sent from my Nexus 6 using Tapatalk
