For 1.5, it is still not parent-child, and it still will not auto-create all the zone players, you have to discover them. All of those changes are part of the upcoming 2.0. But, you are wise to install 1.5, as this will make many changes that anticipate the upgrade to 2.0, and the two installs will actually work together to get from one to the other when it’s time.
So for now, it’s still:
Go to *Apps > My Apps > Sonos"
Click “Create Another”
Luup reload and hard-refresh your browser.
Go to the new Sonos instance and use Discovery in the Settings tab to choose the right unit.
Hello,
I used V1.4 plugin to say messages on different triggers, it worked relatively fine.
Now I installed V1.5, I have the following problem: After playing a message, the music I was playing is not continuing anymore. Every time I have to go to the Sonos app and start whatever it was playing.
Is there a way to read what Sonos is playing, then send a message and continue whatever it was playing again?
Because I didn’t get Google TTS to work properly (It only plays a few times, then it stops) I have created a set of MP3 files on my NAS. With a trigger I send a certain MP3 to the Sonos.
OK. I think that was relatively easy to find/fix. Please install the stable branch release from Github again, using the instructions previously provided. Just for clarity/assurance, that is just an incremental change to the latest 1.5 candidate, not the 2.0 others are installing for Azure TTS.
And while I’m here to say it, given the urgent nature of getting 2.0 to release, it’s unlikely that 1.5 will ever be released through the Vera App Marketplace, as I am now putting the bulk of my efforts into 2.0 released there.
Anyone seeking a stable update of the Sonos plugin that does not need TTS may upgrade to 1.5 (or continue using it). If you need TTS, however, I recommand installing Sonos Plugin 2.0.
I followed all the instructions, but unfortunately the problem is not solved. It looks like the duration parameter is not working like it should.
I also get the following error messages, after uninstalling and removing all the files doesn’t clear the messages anymore… System error : Device: 195. Fail to load implementation file D_FUP_uuid RINCON_7838CA6BD5BA01400_MS.xml System error : Device: 252. Fail to load implementation file D_FUP_uuid RINCON_307E5C9337F501400.xml
You’re getting the system error messages because you have UPnP enabled on the Vera. Those messages are coming from the Vera itself, not the plugin. You can turn that off (unless you have reasons to want your Vera to automatically detect UPnP devices). The plugin’s operation and Vera’s internal UPnP scanning are not related or dependent.
For the “Alert” action, look at your LuaUPnP log file and find the “Alert” actions being called, and see if there are any error messages that follow within 25-30 lines. Let me know what you see.
Ok, I get the following errors after sending a message:
02/23/20 16:46:01.519 luup_log:327: Sonos: error: setData() can’t set CurrentSection on 327 no SID! <0x772bf320>
01 02/23/20 16:46:01.525 luup_log:327: Sonos: error: setData() can’t set r:NextTrackURI on 327 no SID! <0x772bf320>
01 02/23/20 16:46:01.525 luup_log:327: Sonos: error: setData() can’t set r:NextTrackMetaData on 327 no SID! <0x772bf320>
01 02/23/20 16:46:01.526 luup_log:327: Sonos: error: setData() can’t set r:EnqueuedTransportURI on 327 no SID! <0x772bf320>
01 02/23/20 16:46:01.532 luup_log:327: Sonos: error: setData() can’t set r:EnqueuedTransportURIMetaData on 327 no SID! <0x772bf320>
Those aren’t errors. Those are warnings that data being returned in UPnP responses aren’t being saved, because they are not used or supported by the plugin. Anything other than those? Any Lua errors, or anything else in red or yellow nearby?
Maybe this isn’t the place to debug the whole thing… But as long nobody complains…
It’s getting very weird at this time… Now I have to reload the Engine every time before I can play the file a second time… But I get the error:
02/23/20 17:03:45.073 luup_log:327: Sonos: error: UPnP_request (Pause, urn:schemas-upnp-org:service:AVTransport:1): status=1 statusMsg=500 result=[<s:Envelope xmlns:s=“http://schemas.xmlsoap.org/soap/envelope/” s:encodingStyle=“http://schemas.xmlsoap.org/soap/encoding/”><s:Body><s:Fault>s:ClientUPnPError701</s:Fault></s:Body></s:Envelope>] <0x72966520>
50 02/23/20 17:03:45.074 luup_log:327: Sonos: Playing x-file-cifs://192.168.2.9/music/mail.mp3 on 327/0 <0x72966520>
06 02/23/20 17:03:45.101 Device_Variable::m_szValue_set device: 77 service: urn:futzle-com:serviceId:CountdownTimer1 variable: Remaining was: 2698 now: 2697 #hooks: 0 upnp: 0 skip: 0 v:0xeb9480/NONE duplicate:0 <0x75fe8520>
01 02/23/20 17:03:45.165 LuaInterface::CallFunction_Job device 327 function SSonos1_Sonos1_Alert_run failed [string “–[[…”]:2592: attempt to compare number with string <0x72966520>
This tells me you have not installed the update correctly, or you have an old version of the plugin files sitting uncompressed on your Vera together with the compressed ones.
Here is what I suggest:
Copy/paste and run the following Luup code in Apps > Develop apps > Test Luup code: os.execute( "rm /etc/cmh-ludl/*_Sonos*" )
Reinstall the 1.5 stable branch per the previous instructions.
Well if any of you folks feel like giving me a hand I would appreciate it. I was using the old plug in until responsive voice quit on me a few weeks ago. Today I upgraded the plugin to 1.5 and I still cant get TTS to work (within the sonos app) with responsive voice or any of the TTS lua scripts i have in place to work. When using TTS within the app I did get a chime once but that was it. Here is an exert from the log"
RV is dead. The two verified* working TTS remaining for Sonos are MARY and AZURE (Microsoft cloud service). Azure is only supported by 2.0. There’s a separate thread for that.
Edit: Google and OSX may work, but I haven’t tried them, and I won’t be spending time on them in the foreseeable future.
Hello!
I’m trying to get my SONOS works- and no use. I have grouped sonos (Home theater) -Sonos Palybase, Sub and 2x One. I’s Associated Product: 192.168.1.34 - i’ve took it from SONOS Preference.
When i try to discover it- no use. When i manually add the IP - it is the same - take a lok at the screenshots 2020-04-10_16-35-16.png — Yandex.Disk 2020-04-10_16-36-03.png — Yandex.Disk
Can you help me- what i’m doing wrong? Please.
