Version 1.5.26 Released
Good news everyone,
The iPhone 5 optimized version should start appearing in the app store.
Much more to come…
Hi, thanks for the update. Seems that the screen rotation on my iPad 3 is no longer working. App now only works in portrait mode… Anyone else having the same problem?
@al8510,
Welcome!
Just tried on iPad and iPod: portrait only.
No rotation on ipad
Yep, sorry folks. iOS 6 changed how rotation works and while it was supposed to be backwards compatible, well, it isn’t. A fix will be submitted today.
my ipad app quit working, Ive deleted and reloaded it, but it is no longer working. Anyone else having issues?
I had the same issue, I deleted it and re-installed and finally got it to work today.
Hmm… I have 2 to 3 reports of this happening, and I believe all were able to recover by re-installing. It is quite strange as their is no actual code changes in this version (only a new graphic included which makes the iPhone 5 native screen size supported).
Please let me know if you or others experience any other issues. A fix for the autorotation has already been submitted to Apple.
Thanks, I tried a couple more times, and finally about the fifth time, i deleted the app, cleared the memory, and soft reset and re installed it and finally got it working.
I’m having the same problem, crashes on startup. Tried reinstalling numerous times with no luck getting it to run again… Worked great before the update. On IPad3 with iOS 6.01
I am looking into this. All reports of crash on startup / hangs on startup have been on an iPad 3 (not other iPads), at least thus far. Does the app launch if you have the all in portrait mode (home button on bottom)?
Thanks, got it to work in portrait mode, home button down… If started in any other direction it crashes.
Glad you have a temporary work around and sorry for the inconvenience. Hopefully the new update appears in the app store soon.
I am looking into this. All reports of crash on startup / hangs on startup have been on an iPad 3 (not other iPads), at least thus far. Does the app launch if you have the all in portrait mode (home button on bottom)?[/quote]
I confirm, when using portrait mode the app starts, in landscape i only get a black screen, also using ipad3.
