Verifying plugin compatibility before upgrading
I recently purchased a Vera edge to upgrade my Vera lite, which is going to force an upgrade to UI7. I want to verify that the plugins I am currently using will work in UI7 (after I update them), but I’m having trouble find a way to verify an app will work.
I’ve gone through a bunch of the forums and I sure these will work:
-Nest Thermostat and Protect
-Day or Night
-DSC Alarm Panel Plugin
-Harmony Hub Control
The ones I haven’t been able to find out are
-Google Calendar Switch
-WakeupRamp
-Virtual ON/OFF Switches
-WOLPlusPing
-eMail Notification
-Garage Door
-Twilio.com API Interface
Is there an easy way to check them? Is their something I’m missing when I look at the App information that lists versions compatibility?
Take a look here:
http://forum.micasaverde.com/index.php/topic,26438.0.html
