VeraPlus - ServiceIds reporting incorrectly
Hi All,
I’m trying to set up a reactor device to monitor the power used by our washing machine, via an Aeon Heavy Duty Switch, however the serviceId for the device is reporting a generic:
urn:micasaverde-com:serviceId:ZWaveDevice1
Unfortunately the same is happening for other devices, who I already have this setup for, and working, so I can confirm that the serviceId is no longer being shown correctly.
Steps I’m using, find the device, advanced, variables, and then hover the mouse pointer over a variable name.
Why is this happening?
Tony
That is correct sevice id for metering
see list here
http://wiki.micasaverde.com/index.php/Luup_UPnP_Variables_and_Actions#ZWaveDevice1
Thanks ElCid, that would be fine, however I get the same value when I check for my humidity sensor, which I know uses the serviceid urn:micasaverde-com:serviceId:HumiditySensor1 (Aeotec 6 in 1 sensor - humidity).
What do you get if you click edit rather than hover?
Hard-refresh your browser? How to do Hard Refresh in Chrome, Firefox, Edge and Mac’s Browser?
Ah, figured it out. For most of the variables, it gives the generic zwave device, however for watts, it gives energymeter1.
