veraplus + netatmo thermo + weather not installing
both the thermo and weather station are certified products but when Adding them i get no response from the veraplus, tailing the logs does not show anything useful.
anyone else had issues ?
Same issue here. Add device, click on the > next to Weather Station, and… nothing.
Unfortunately. Yes.
Log a support ticket, enable remote support and eventually someone will connect and install the plugins for you but they are all in French and for what it’s worth the plugin is more or less useless
There is an excellent plugin available for the Netatmo Weather Station that you should be able to find from the Apps store but unfortunately it does not have support for the Thermostat.
More info here → http://forum.micasaverde.com/index.php/board,73.0.html
