VeraPlus - hard factory reset?
Didn’t have much luck shifting my Vera3 and copying over to the new VeraPlus, it seems to have botched half way through. The VeraPlus is now stuck on startup and never gets luup loaded. Decided I’m just going to factory reset and manually rebind all 100+ devices (can’t wait…). So I’ve been trying to hardware reset this thing - I’ve tried holding in the reset button during powerup, holding in the reset button for 30+ seconds after powerup, combinations of Select/Sync buttons while pushing the reset button, combinations of Select/Sync buttons while powering up, but still no factory reset. Does anyone know the magic combination to reset this thing (or another way to factory reset w/o luup engine being up)?
Were you able to figure out how to hard reset it?
Did you try to SSH into it using root and the default WiFi password?
For reset factory, press 6 times on reset button
3 times is for reset network
Yeah, talked to support and they told me about the 6 times in the 6 seconds, but that still didn’t fully reset even after resetting the z-wave network. They tried a lot of other things and then continued to work on it via ssh for a while after the call. Eventually they got it reset and asked me to try copying again. However, after this experience I think I will just manually migrate the devices over. Good news is, whenever they finally reset me I no longer have the phantom _Scene Controller.
