Being new to Vera and trying to learn about my new VeraPlus I read a post by one of the more experienced members. He mentioned the side buttons ( xxx, include-exclude) on a Vera unit. The topic I was reading talked about the older unit having batteries.
I got me thinking the buttons on the VeraPlus (select, sync) are probably used to pair / include a device using the VeraPlus when not connected to the LAN.
For me power is usually not a problem, all my devices are withing a 15’ extension cord from a plug but LAN is more difficult (yes I could get a really long CAT5).
My test to see if I could use the buttons to include a device:
- Using a GE link bulb.
- Unplugged LAN cable from Vera
- Turned on GE bulb
- Pushed “select” button until the “zigbee” light was the only radio light on.
- Pushed the “sync” button.
- The GE blinked once (maybe twice)
- Pushed “select” to see if I could change the mode to all radio lights on, but could not.
Reconnected LAN to Vera, and logged in. The GE link bulb was not paired. I was able to pair it with a Generic Zigbee device.
So I think there is a way to include devices without a LAN, however I’ve not yet found it. Perhaps it only works with a device specifically in the Vera device list. If someone has other ideas or information I would appreciate a post.
BTW: If all this is already on some Vera site I haven’t found I’m going to be really embarrassed.
JohnRob
