Veramate IOS - 1.6GB storage use??
Just had to delete App. Was using 1.6GB of space on my 5s
Anyone else?
[quote=“paulcusick3, post:1, topic:185191”]Just had to delete App. Was using 1.6GB of space on my 5s
Anyone else?[/quote]
Hmm, ok that… might not be right :/. I’ve just found out the logging library I’m using sometimes doesn’t remove older files properly. The only way to clear this at the moment is to reinstall the app, or select the “reset on next start” setting - this will unfortunately remove any VeraMate settings.
8.6 is currently queued with Apple, I’ll place a fix for this in 8.7 which will have to be 1.5 to 2 weeks from now.
