VeraLite vs Vera3
Could you tell me the differences between the two and the pluses and minuses of each one?
http://wiki.micasaverde.com/index.php/Comparison_of_Vera_units
Vera 3 has everything the Vera Lite has and it also includes a WiFi access point(not a WiFi client node), ethernet switch ports, and router/firewall capabilities. Most people already have a router/firewall and WiFi access point, so why would they use Vera 3 rather than Vera Lite? The only reason is the additional memory. The Vera 3 has twice as much memory as Vera Lite.
Additional memory can be important if your home automation setup will have lots of devices, scenes, and plugins. Micasaverde says that Vera Lite can handle up to 70 devices, whereas the Vera 3 “easily handles 200 devices”.
If you think you’ll have near 70 or more devices and plugins, then get Vera 3. If you’re confident that you won’t approach 70, then get Vera Lite, it’s a bit cheaper. But, having said that, little in the Z-Wave world is cheap. At $40 or more per switch, it can be an expensive endeavor.
Thanks for the explanation.
[quote=“Z-Waver, post:2, topic:176711”]http://wiki.micasaverde.com/index.php/Comparison_of_Vera_units
If you think you’ll have near 70 or more devices and plugins, then get Vera 3. If you’re confident that you won’t approach 70, then get Vera Lite, it’s a bit cheaper. But, having said that, little in the Z-Wave world is cheap. At $40 or more per switch, it can be an expensive endeavor.[/quote]
Actually the Vera3 can be used as a WiFi Client, I have used this feature when testing vera positioning where there is no ethernet (I have Apple extreme router connected to broadband), can be found under Setup > Network WiFi > Advanced settings. (Firmware 1.5.622)
David
My mistake. I was under the impression that this configuration was no longer working.
The wifi option of the Vera 3 is the most important reason i had choosed the Vera3 as i have a house with 2 layers, living room at the ground and some little rooms on the 1st floor. The modem (with wifi) from my ISP can not reach the rooms on the 2nd floor as houses in Holland are made from concrete with much iron in it. My Vera is on de 2nd floor.
