Allowed the upgrade to UI7 occur on the veralite the same weekend as I installed a RF receiver to the vista 20P panel. Now the ad2usb app is having issues. I uninstalled and reinstalled several times and finally the interface was appearing. Now the connection is down and the Vista partition isn’t recognizing the virtual panel.
Has anybody else experienced these issues and found a resolution?
I started from scratch with UI7 and could not get it to work. I had to downgrade to UI5 and follow a bunch of steps to get the USB port to work. I will try UI7 with Raspberry PI since I can’t get the stupid USB port to see the AD2USB in UI7. Maybe over the network it may work.
[quote=“ltemplin, post:1, topic:182820”]Allowed the upgrade to UI7 occur on the veralite the same weekend as I installed a RF receiver to the vista 20P panel. Now the ad2usb app is having issues. I uninstalled and reinstalled several times and finally the interface was appearing. Now the connection is down and the Vista partition isn’t recognizing the virtual panel.
Has anybody else experienced these issues and found a resolution?[/quote]
