I just received a new VeraLite controller, and I downloaded and installed the Nest Thermostat plug-in. However, in the “Devices” tab, if i click “Settings” and enter my Username, password or polling interval, then click “Set”, I immediately receive the error: Device not ready.
Also, at the top of the screen is the message: Nest : Version 1.5.408 minimum required to run
[quote=“mthumphrey, post:1, topic:182811”]I just received a new VeraLite controller, and I downloaded and installed the Nest Thermostat plug-in. However, in the “Devices” tab, if i click “Settings” and enter my Username, password or polling interval, then click “Set”, I immediately receive the error: Device not ready.
I have the VeraLite with Firmware 1.7.318[/quote]
This thread has a new file for you to upload to get past the incorrect error message:
However, there remain display problems on UI7, and I still await documentation from the Vera folks on how to make plugins appear properly on UI7 that work correctly on UI5. Once I have been given authoritative information on this, I will try to update it, but I do not have a Vera unit that can run UI7.
I read reports on the other thread that it works properly under UI7 if you control it from a mobile app like AutHomation (Android), but reports of it looking wrong on UI7 natively seem universal among those who reported their findings. So you can get it to work – sort of – on UI7, but an update that makes it look correct in UI7 is somewhere in the future.
