VeraLite Slaved to VeraPlus can it be reset Master
VeraPlus arrived UK supplier.
Veralite running UI5 so when login to home.getvera.com, no selection for Veralite.
Decide to setup VeraPlus and select UNPNP on VeraPlus, when complete received lots of errors relating to plugin files missing. Installed plugins on VeraPlus.
Combination Switch
Virtual Switch
PLEG
Vera Alerts
HomeWave Push
etc
Resolved the missing files issue
Checking Veralite is now set to Slave
VeraPlus has lots of _Appliance Modules which are difficult to track down what they are.
Also all the devices are in “No Room” scenes are not on VeraPlus
I created a VeraLite backup before transfer to slave.
My Question I tried loading the VeraPlus backup file, but it remains set to Slave.
How do I set VeraLite to Master without loosing my original associations.
I would then do a factory reset and attempt a to Upgrade VeraLite to VeraPlus
I also find UI7 very slow when I make a change to device ie I started to create rooms to move the device into there correct order.
