VeraLite not saving changes
When I make changes to vera scenes, PLEG conditions triggers or actions, and Vera Alerts plugin my VeraLite doesn’t save the changes, even when reloading LUUP.
I have been Using my Vera Lite for close to 2 years now and this is the first time I have had this issue. I don’t believe this issue is with the plugins. When I make changes to a scene (i.e. setting a dimmer to 40%) VeraLite goes through the motions of saving the changes. However when I go back into the scene the changes didn’t save (i.e. the dimmer is still set to 100).
After about a dozen attempts, the changes will finally save. I don’t know if the issue is caused by the recent addition of a few devices but I have noticed more frequent restarts.
Any Ideas what could be causing the issue?
Using VeraLite UI7 fwv 1.7.855
PLEG verson 7.48
VeraAlerts version 7.15
