I went to update my firmware to 346 fr without reset factory settings.
Now, my vera boot normally, 3 leds are OK, I can ping my Veralite.
If I try to go to http://my_ip_veralite , the window shows me “Loading” and that’s all… It’s blocked here…
Can you help me?
I notice I can connect me to vera by SSH
My scenes work fine. Shutters window are closed now…
I don’t understand… when I connect to my_ip_vera, that’s blocked on “Chargement des données”… “loading data”
Now, It’s good!
I just connect to micasaverde.com, login & password and my dashboard is opened.
After that, I try to connect on my_ip_vera on my LAN and that’s work fine…
Very bizarre.
What was happened?
