VeraLite - Failed Firmware Upgrade Before First Use
Hello, I have the VeraLite (off white colored box, not the green one I have seen everywhere). I don’t even actually know what UI or firmware version it shipped with. It was a combo kit box from Tiger Direct (in the actual store, not online).
  1. I created a login with no issue.
  2. Connected the VeraLite normally into my router the device was recognized and ordered me to do an upgrade before I proceeded with no other ability to bypass that I saw.
  3. During the upgrade received an email “Unit Notification” with an email validation code.
  4. At some point I got a download failure on the screen. No buttons or options to retry or fix that I saw.
  5. At this point, the unit never connected again to my network.
  6. After head banging I realized it was at least partially bricked due to the firmware failure.
  7. I confirmed the device will NOT use DHCP at this point.
  8. I set my computer to manual IP 192.168.81.2 with gateway of .1.
  9. Both of those IP’s are pingable. .1 Does load the web server interface and presents me with “root”.
  10. I cannot get any access to the password using the nvram grep command or using the password stored in the backup because a backup has never been made.
  11. I can confirm that I can accept the key for first time SSH connection but without a password it doesn’t help me.
So…
I was wondering what to do next. Here is what I think:
  1. Set home router to wireless repeating option and connect the VeraLite to the other router. From my research I should be able to get internet access while having the two different subnets (192.168.1.1 and 192.168.81.1).
  2. All I need to do is then launch http://192.168.81.1/cgi-bin/cmh/upgrade_step1.sh **Is this correct or should the IP be 81.2?
Any other options, ideas, considerations or information I can provide?
I’ll be getting a support ticket created but I wanted to get this information on the forum first.
I am in contact with support. I also see this post and found that VeraLite and Vera3 share the same firmware but I will work with support and hopefully attemp to make use of the recovery tool if possible.
http://forum.micasaverde.com/index.php?topic=9416.0
[quote=“tomtcom”]I am in contact with support. I also see this post and found that VeraLite and Vera3 share the same firmware but I will work with support and hopefully attemp to make use of the recovery tool if possible.
http://forum.micasaverde.com/index.php?topic=9416.0[/quote]
Support ssh’d into the device and executed the commands to reload the firmware. I’m up and running now.
Sent from my Nexus 5 using Tapatalk
