Hello! This is my first post - I will try to keep it quick and concise. (Also, I have spent hours reading the forum for an answer, and if it is there, I can’t find it - any direction would be great).
My current config (only relevant pieces listed):
Controller - Veralite
Alarm - DSC1616
Alarm Adapter- Envisalink EVL-3
Bridge - TP-LINK TL-WR702N
Plugin v. .38, I believe.
Ok, so I have everything set up, and the EVL-3 seems to be working well. I can access it/arm it/etc. through the iPhone app. I can view the zones on the Veralite App, and on cp.mios.com. I can move the zones around on there, rename them, set alerts, etc. However, that is all I can do when it comes to connection with my Vera. On the cp.mios.com page, I cannot change any of the settings. I see nothing under the panel (and more times than not receive the Lua Failure).
I have set the EVL-3 up on a static IP, and again, I can communicate with it very well through the EyezOn App, as well as directly through the device’s IP address.
Maybe I am looking for functionality that doesn’t exist? I would have through there would be more to the “panel” on the MiCasaVerde site - there is nothing, with no control over the device. It sees the device, I suppose, but that is all (also, when I do go to the setup of the panel, it does not have an option for the EVL-3, just the two older methods of connection.).
Can anyone tell me what the functionality is supposed to be? Possibly some suggestions on why mine may not be working? (also, in the drop down under Controlled Via, I am hesitant to change it from the default of “no parent” as it threatens to brick my Vera).
Thanks all! I appreciate the guidance!!!
