Is it possible control the same Z-Wave switch with the GE 45601 and the veralite. What I want to do is be able turn A lite on and off the the remote and the veralite,just learning.
thanks Jim
thanks Jim
Yes.
Would it be possible for you to start me in the right direction.
It’s been a while since I’ve done it, but pair the remote to the switch using the instructions that came with the remote. Separately, pair the Vera to the switch. I use the remote independent of Vera, that is, Vera sees the remote, but the remote doesn’t control anything through Vera. I only use it for a couple of lights that are far from their switches, so the remote is mainly a “portable switch”. I believe they sell the remote intended as the controller, as opposed to buying a Vera or other alternative.
