Running Version 1.7.1598
Latest Version 1.7.1707
I’ve tried a dozen different things and I’m stumped. No matter what I do, I get a 404 not found error after the page where you can save your backup, then specify keep settings vs factory reset (this is upgrade_step3.sh). I can do an inspect on the page to see that the “start upgrade” button points to a file upgrade_step4.sh, and that’s where I get the 404 error.
I’ve ssh’d into my Vera and gone to the /www/cgi-bin/cmh folder and lo and behold upgrade_step4.sh doesn’t exist! That explains the error, but how does one do an upgrade?
I can see that most of the files in /www/cgi-bin/cmh point to /mios/www/cgi-bin/cmh and that in that folder there is an upgrade_step4.sh file…
EDIT - giving it a shot - created a symlink to the missing upgrade script and seeing what happens! Moved to the next step and has the timer counting up, but only time will tell…
