VeraEdge: How to Restore Backup
When I restore my Vera Edge I have no devices. When I backed it up I had 12 devices. I tried uploaded a backup that I had stored on my PC hard drive and I tried restoring internal backups. Still no devices.
Is this some procedural thing of am I confused and backup doesn’t backup devices. If not that seems really stupid. I would kind of hate to have to restore my network from scratch. It appears to have restored my scenes and rooms but no devices.
I could not get a device to reconnect properly even after unpairing. So my strategy was to start over and restore the backup. Maybe it was so messed up that the backup didn’t work OR I am misunderstanding the concept of backing up the controller.
Can someone enlighten me?
There is a checkbox on the restore screen to restore the zwave network. I checked it and restored a backup. Not sure how I would do that to a backup I uploaded to a pc.
:(Same story, 2018! NO answer?
Here is what I typically do:
  1. Just before I backup, I backup z-wave network (see screen shot below).
  2. When z-wave backup is complete (may take about 15 minuted), I select create back up, which prompts me to save it to a local drive. I use a NAS to safeguard my Vera files. I have quite a few saved backups with the z-wave network.
Not sure why no one responded all these years. It is pretty obvious to me how to back up my Vera.
This forum uses the applaud instead of like.
[quote=“Don Phillips, post:4, topic:185330”]Here is what I typically do:
Not sure why no one responded all these years. It is pretty obvious to me how to back up my Vera.[/quote]
Interesting—I have a fairly large Z-Wave network and my back-ups take less than a minute on my VP.
Hey there,
a backup can be restored from Settings-> Backup → pick a backup from the list, check the box for “Restore Z-Wave network”, then press on Restore.
Unless there is some kind of issue with the backup file, in which case the Customer Care can have a look as well.
[quote=“HSD99, post:6, topic:185330”][quote=“Don Phillips, post:4, topic:185330”]Here is what I typically do:
Interesting—I have a fairly large Z-Wave network and my back-ups take less than a minute on my VP.[/quote]
It is probably related to me using a Vera 3. It seems, regardless of size of the network, it takes the same amount of time.
