Hi, i’m trying to setup a security system with a vera edge and some fibaro door sensor… all work well, but it seems that if a door sensor is armed and is opened and closed in less than 5 secconds it will not trigger an alarm.
In the alerts log I see that if an alarm is fired i’ve got an event of type “Burglary”. In the case the door is opened and closed fastly I’ve got an event of type “Device changed Status”.
How can I remove this “pause” and fire immediately and always the alarm?
