VeraEdge and Vision ZG8101 garage door sensor
Hi togehter,
my name is David and I’m from Germany, so don’t be so harsh with my english :wink:
I just bought a VeraEdge in order to act as a middleware for my z-wave devices in my entirely home automation installation (most of it consists of KNX and the rest are enocean, z-wave and Zigbee devices). My primary controller for logic and the mediator for all different device types is a Intel NUC with the open source home automation project “openhab” installed on it. Openhab also has a binding for z-wave, but supports not as many devices as MCV does. Therefore it was a compromise depending on functionality and costs for me to buy a VeraEdge.
So, after this short introduction - here is my question:
The above called Vsision ZG8101 garage door sensor works as a generic device with VeraEdge (UI7). At first it was detected as a motion sensor. Then I found out (with help of this great forum), that I can change the device type to a door sensor. This is working well. But at the end I’m missing the battery level. Is it possible to convince my VeraEdge to report it?
Thank you very much!
[size=10pt]Ohhh my fault - it is working now.[/size] After the last night it works with reporting a battery level. Ok it took a while but finally it works. Sorry for circumstances - the post can be closed. At least I’m presented myself and my home automation solution ;D
David
I’m also new to Vera. How did you change the device type?
