I’m not sure if anyone has used a 4 button keyfob with the VeraEdge??
I recently grabbed one of these:
http://www.popp.eu/products/controllers/kfob-remote-control/
as I wanted to use it as a scenario controller however, it seems to be a little tricky to setup??
The guides I’ve studied so far are:
http://www.vesternet.com/resources/application-notes/apnt-67#.V9XZ-HWlzrd
http://www.z-wave.info/include-the-kfob-wall-c-in-the-gateway-vera-lite/
and of course the product manual:
http://www.popp.eu/wp-content/uploads/2015/11/Manual_KFOB_POPP-C_En.pdf
Since the VeraEdge is Z-wave Plus capable I thought using the parameter code of 8 would work for variables 11-14??
I have also tried 4 and 5 too. With a value of 4 the buttons seem to control the Scene I told the Vera to use for the 4th button, but when I push any button it seems to activate it??
So describing what I’ve done so far is this:
Created 4 Scenes to turn lights on (this is just as test for now as ideally I would like to also turn them off too but still learning about the Vera )
In the Scenarios as trigger I setup the keyfob buttons 1 through 4 for each Scene then as output told the Vera to turn the relevant lights On.
The keyfob itself has been paired with the VeraEdge and is happily reporting status back.
I believe I have put the keyfob into Secondary Controller mode but the guides from Z-wave.com seem to suggest different things??
For the Vera-Lite it says to go to Management Mode on the fob then press button 2, while for the Vera it says to push button 1??
http://www.z-wave.info/service/
Would anyone know a way in which I could get this device to function as a Scenario controller with the VeraEdge as I’m sure it’s possible it’s probably just me not understanding 100% of how…
Many Thanks.
